zooming map from selection in table
2722
07-13-2023 09:09 AM
mikaël
I have a dashboard with a map that includes a polygon layer and a table where the polygon id are shown. If I click on an id in the table, the map zooms to the polygon, which is correct.
I have another flat table that also contain the polygon id. How can I make that when something is selected in this table, the map zooms to the polygon? I have the filter option action (which works), but not zoom.
Left side table is the same source as the polygons (layer). Bottom table is a flat table that contains a field that I can match to the layer. How to zoom ??
Thanks!
mikaël
As suggested by jcarlson in another one of my questions, the trick is to have an element (in my case, a table) that has a geometry and then when clicking on a feature, it will zoom at that feature on the map, even if not present. So if you have a layer with the same geometry on the map, then it looks like it's zooming to that element, although it's technically a different source.
mikaël
