Vertical Alignment List Widget
1661
04-24-2025 10:36 AM
BJR
Has anyone built an ArcGIS Dashboard that vertically aligns a List Widget within the box? I have tried all sorts of HTML in the Advanced formatting, I have tried the JSON in the Assistant and I have not found any technique that achieves dynamic centering across multiple screen sizes.
Here is my existing Source code
<p style="text-align:center;">
    <strong>Average Dwell Time</strong>
</p>
<h2 style="margin:0;text-align:center;">
    <span style="color:hsl(238,72%,63%);font-size:24px;"><strong>{field/avg_dwell_time}</strong></span>
</h2>
RPGIS
by MVP Regular Contributor
Hi @BJR,
One thing you can try is creating a table within a table and setting the alignment values via html on the inset table. I have used that method to center a table based on cell height.
<table border="{expression/tborder}" cellpadding="0" cellspacing="0" style="height:80vh">
vh uses viewport, aka screensize, when setting the height of a table so be careful when using that but it will allow for values to center based on height. I too have this issue and I am trying to find a work around but this is what I am testing currently.
Julia_Levermann
Try using flexbox to vertically align your text within the list element:
This blog post gives a good overview of flexbox and grid CSS: https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/spruce-up-your-pop-ups-with-css
BJR
Unfortunately this doesn't work - across screen sizes the list widget still maintains center within the box and not the widget itself. Im no css pro but it seems like the css of the dashboard itself overrides the widget forced-css
