Using multilayers
1981
10-17-2023 10:47 PM
NasratullahOmari
Hello everyone!
is it possible for any of ArcGIS Dashboard elements to reads from more than one layer (Data sources) at the same time?
Thank you!
IssyAmis
Hi @NasratullahOmari
Thanks for your question, would you be able to provide some more information on what you are trying to achieve?
Many thanks!
Issy
NasratullahOmari
for example, I want that my indicator element read from two reference layer (data source), so is that possible?
Thanks
MlondiNdlovu1
Why don't you use a data expression and  you can combine the two data sources there into a single dictionary. If you're just interested in one field, you can just specify that in your dictionary.
you can have a look at this: https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/CombineMultipleLayers(SerialCh...
I hope this helps.
NasratullahOmari
Thanks @MlondiNdlovu1 . Yes, this is helpful for someone who knows about the data expression and Arcade.
