Using data expression to find intersection with separate polygon layer
1934
9
08-21-2025 08:59 AM
ChristineLazina11
Hello all!
I'm hoping to find some help troubleshooting this Arcade code used in a data expression for a dashboard. I'm far from an expert on Arcade so there may be something silly I'm misunderstanding.
The situation:
I have one large feature layer of all sewer lines in our network, that I am looking to break into 3 separate service areas in the dashboard, so I can track stats for each service area separately. (Unfortunately I do not have the ability to edit this UN sewer line layer, and there is not an appropriate attribute in existence to filter for these service areas without using a spatial query).
My code:
//Define the Enterprise portal connection
var myportal = Portal("https://samplesite.net/portal"
// Get the line layer: UN - Sewer Lines
var SewerLines = FeatureSetByPortalItem(
    myportal,
    '2c08361d8abe4308afba3d25c857a11c',
    3,
    true
// Get the polygon layer: Separated Service Areas,
//filtered for Core Service Area feature only
var CoreSvcArea = Filter(
    myportal,
    '41c17045b4cf4359a8237db163fe82a6',
    0,
    true),
    "ServiceAreaName = 'RVSS Core Service Area'"
// Create an empty array to store intersecting features
var CoreLines = []
// Loop through each sewer line
for (var line in SewerLines) {
    //Check if the given line intersects any core service area polygon,
    //Filter() returns those intersection polygon features (if any) in
    //a new array called intersxtion
    var intersxtion = Filter(CoreSvcArea, Intersects(line, CoreSvcArea))
//If count of features in intersxtion is not 0, means an intersxtion
//with given line exists, and it is added to the end feature set
    if (Count(intersxtion) > 0) {
        // Add the intersecting line to the result array
        Push(CoreLines, line)
// Return the intersecting sewer lines as a FeatureSet
return FeatureSet(CoreLines)
Issues:
When I test this code it returns the error "g.charAt is not a function". I believe I have isolated the issue as coming from the filter/intersection expression on line 34, but it could potentially be from the next few lines of code in the loop expression as that was a bit hard to isolate and test directly. Can anyone tell me what functionality inside this expression would be trying to call a string and not finding one? (this is my understanding of the error). Or if there is a better way to achieve the identification of overlapping features in this scenario I'm all ears!
Many thanks for any insight,
Christine
KenBuja
MVP Esteemed Contributor
I had edited my first response to explain why you were getting that error.
In addition, there was another issue with your code. A data expression has to return a FeatureSet, but you were returning an array. You would have to convert the array of lines into a FeatureSet to use it in the dashboard.
This code should work when a service area is comprised of multiple polygons
var myportal = Portal("https://samplesite.net/portal");
  myportal,
  "2c08361d8abe4308afba3d25c857a11c",
  3,
  true
var CoreSvcAreas = Filter(
    myportal,
    "41c17045b4cf4359a8237db163fe82a6",
    0,
    true
var dict = {
  fields: Schema(SewerLines)["fields"],
  geometryType: Schema(SewerLines)["geometryType"],
  features: []
for (var CoreSvcArea in CoreSvcAreas) {
  for (var line in Intersects(SewerLines, CoreSvcArea)) {
    var attributes = {};
    for (var attr in line) {
      attributes[attr] = line[attr];
    Push(dict["features"], { attributes: attributes });
return FeatureSet(dict);
KenBuja
Is each of the CoreSvcAreas a single polygon or is it multiple polygons? If it's a single polygon, then you can make this much simpler
  myportal,
  3,
  true
// filtered for Core Service Area feature only
// This works only if there is one polygon per service area
var CoreSvcArea = First(
  Filter(
      myportal,
      0,
      true
return Intersects(SewerLines, CoreSvcArea);
You were getting that error in the Filter function since you had a syntax wrong. Filter expects an SQL expression (a string) as the second parameter, but you were supplying it a FeatureSet (the result from the Intersects function)
ChristineLazina11
@KenBuja thanks for your quick reply! Currently each service area is covered by a single polygon, but in the future I believe we could have multiple polygons in use for a single service area, so I was trying to cover that possibility... That being said, your code did work perfectly so it might be worth it for me to just go with that and cross the multiple poly bridge if I come to it!
Just for my own edification, do you have any idea why my original expression may have been causing the error?
Thanks so much, Christine
KenBuja
  myportal,
  3,
  true
    myportal,
    0,
    true
var dict = {
  features: []
ChristineLazina11
@KenBuja Got it, that makes sense re: the Filter() parameters. And thanks so much for supplying that code for multiple polygons, that's awesome! I appreciate all your help.
KenBuja
After giving this a little thought, there's an even faster way to do this. Cycling through each set of lines in each service area polygon to write them to a dictionary is pretty inefficient. Instead, this version unions each of the service areas into a single polygon to use in a single Intersects function. And if there is only one polygon in the service area, it skips that step.
  myportal,
  3,
  true
    myportal,
    0,
    true
// return the intersection if there's only one service area
if (Count(CoreSvcAreas) == 1) return Intersects(SewerLines, First(CoreSvcAreas));
// otherwise, union the service areas together and return the intersection
var areas = [];
for (var area in CoreSvcAreas) {
  Push(areas, area)
return Intersects(SewerLines, Union(areas));
ChristineLazina11
Amazing, there are a decent number of records in the datasets I'm working with so any increased efficiency is well appreciated. I will use that option going forward!
LukeGilner1
Can I hijack this thread with a similar situation, please?
I know very little arcade and have been going through a run around with CoPilot to try to help.
I'd like to intersect a tract layer (325 features) with a lakes layer (11,200 features) for a data expression in Dashboards.  I'd like to get a Count of the number of lakes that intersect all the tracts, just one number.  I'd also like to get the acres as well, but just working on Count right now.  The tract layer can be merged into one feature if that is possible in the data expression, if it would help speed things up.  Here's what I have so far, but it gives me an error of: Test execution error: "[object Object]" is not valid JSON. Verify test data.  Again, I know very little arcade, so I probably have something wrong.
var port = Portal("https://www.arcgis.com");
// Load layers
var tracts = FeatureSetByPortalItem(port, "b9fcbedac0384e32bc3dba6aec1a8cf6", 0, ["OBJECTID","TractKey"], true);
var lakes = FeatureSetByPortalItem(port, "5564b2e702364aefba08df8c95216a1f", 0, ["OBJECTID","Shape__Area2"], true);
// Prepare output schema
var fsDict = {
    fields: [
        { name: "OBJECTID", type: "esriFieldTypeOID" },
        { name: "Shape__Area2", type: "esriFieldTypeInteger" },
        { name: "LakeCount", type: "esriFieldTypeInteger", alias: "Lake Count" }
    geometryType: "",
    features: [],
// Loop through each tract and count intersecting lakes
for (var t in tracts) {
    var tractGeom = Geometry(t);
    var countLakes = Count(Filter(lakes, Intersects(Geometry(lakes), tractGeom)));
    var f = {attributes: {OBJECTID: t.OBJECTID, Shape__Area2: t.Shape__Area2, LakeCount: countLakes}}
    Push(fsDict.features, f)
return FeatureSet(fsDict);
KenBuja
You should start a new discussion when asking a question like this. Also, when posting code, use the "Insert/Edit code sample" button. It makes it easier to read and refer to specific lines.
There are several problems in this line.
You don't need to filter the results of the Intersects function and even if you did need it, you weren't providing the required sqlExpression. The Geometry function takes a feature as an input instead of a FeatureSet. And in the previous line, you don't need to cast t as a Geometry.
Try this instead
var countLakes = Count(Intersects(lakes, t));
LukeGilner1
@KenBuja Ok, sorry about that.  I'll start a new post for my next questions as I'll be working on some other similar intersects and such.
Your suggestion worked!  It gave me an error about key not found for Shape__Area2, so I just got rid of that in the loop section for now.  This produced a dictionary of the number of lakes in each tract.  I was able to use the Sum statistic in the Indicator widget to produce a total number of lakes.  It runs a bit slow, but gives me what I was looking for.  Thanks!
