Using Arcade to change Datetime from UTC to CST in Dashboard
2837
11-16-2022 02:05 PM
ThomasRickett
We have a data stream that is displaying times in GMT. We would like to changed multiple to CST (-6 hours).
I see the Date functions in Arcade might work.
https://developers.arcgis.com/arcade/function-reference/date_functions/#tolocal
DateAdd shows this
var startDate = Date($feature.dateField);
var oneWeekLater = DateAdd(startDate, 7, 'days');
return oneWeekLater;
Can I change that to
var Sixhoursago = DateAdd(startDate, -6, 'hours');
return Sixhoursago;
I want to change all these fields.
jcarlson
Yes, date functions would be the way to go. Since you're doing this multiple times, you may also want to use a custom function.
function GMTtoCST(d){
    return DateAdd(d, -6, 'hours')
var d1 = Now()
var d2 = Date('2022', '5', '27', '15')
var d3 = Date('2017', '8', '11', '8')
Console(d1, GMTtoCST(d1))
Console(d2, GMTtoCST(d2))
Console(d3, GMTtoCST(d3))
- Josh Carlson
Kendall County GIS
ThomasRickett
Thank You Josh!
This is a big help. I need a bit more help with it since I'm not to familiar with Arcade.
Do I replace d1-d3 with
{bcs_time_first_unit_assigned}
{bcs_time_first_unit_arrived}
{bcs_response_time_depart}?
How would I call the function in the line item template to have just CST show?
Thank you so much again Josh!
jcarlson
Up in the Advanced Formatting area, you'd add these converted times to the attributes section, like this:
return {
    attributes: {
        assigned: GMTtoCST($feature.bcs_time_first_unit_assigned),
        arrived:  GMTtoCST($feature.bcs_time_first_unit_arrived),
        departed: GMTtoCST($feature.bcs_response_time_depart)
Then in your line item template, you pull out individual attributes like {expression/assigned} and so on.
- Josh Carlson
Kendall County GIS
SarahRijneke
I've created an application that shows snow plow clearing in my city. It's supposed to show when a street was last plowed (under 4hrs ago, 4-8 hrs ago, 8-16 hrs ago, 16-24hrs ago). There is a 5hr delay between the timestamp field an my local time zone (EST) so the app isn't showing the data correctly. How can I use arcade to correct this?
Here's an example of my expression for the 16-24 hour time frame:
if (DateDiff ( now() ,  Date($feature.Time_Stamp) , 'hours' ) > 16 && DateDiff ( now() ,  Date($feature.Time_Stamp) , 'hours' ) <= 24 ){
    return "16-24 Hours"}
else {return "No Data"}
