Use chart widget to filter multiple feature layers in map
854
11-23-2020 08:45 AM
jonasvanduijvenbode
HI,
I have a chart based on a point layer. The data behind this point layer has a column that is also shared in a polygon and line layer. All three layers are shown in a map within the dashboard. With the category selecter I can use the grouped values of the point layer and add an action to filter all three layers in the map based on the selection. However, I can only select the point layer as a filter action when I use a chart widget (clicking one of the bars in the chart should only show the features that have the corresponding values in the same column).
Is there a work-around here to still get this done? I would like to not have category selectors if possible.
Tags (1)
