Hi! I'm trying to build a data expression in an ArcGIS Online dashboard that will take a field called, HOUR_OF_CRASH, which is an integer field and not a time field, and populate a new field called, TOD, which will be a text field for the time of day the hour falls within so that the new field can be used to build a pie chart within the dashboard. The current data expression is shown below.
var portal = Portal("https://www.arcgis.com");
var fs = FeatureSetByPortalItem('d651aa4112e5408ea9a1cfabecd6485c', 23)
// Create schema for the returned FeatureSet
var fields = [
{ name: "HOUR_OF_CRASH", type: "esriFieldTypeInteger" },
{ name: "TOD", type: "esriFieldTypeString" }
var features = [];
for (var f in fs) {
var hour = f.HOUR_OF_CRASH;
var tod;
if (hour >= 0 && hour <= 5){
tod = "Night";
} else if (hour >= 6 && hour <= 8){
tod = "Morning";
} else if (hour >= 9 && hour <= 15){
tod = "Day";
} else if (hour >= 16 && hour <= 23){
tod = "Evening";
} else {
tod = null;
Push(features, {
attributes: {
HOUR_OF_CRASH: hour,
TOD: tod
}Unfortunately, this data expression won't function within the dashboard and doesn't give me quite the output I am looking for in the end. See the below image of the output.
My experience with data expression is relatively limited. Any advice would be greatly appreciated!
Bec
Hi @Bec,
So the issue is that you are not returning a feature. When creating a custom data expression you should return a value similar to the one below.
var fields = [
var features = [];
for (var f in fs) {
var tod = When( hour >= 0 && hour <= 5, "Night", hour >= 6 && hour <= 8, "Morning", hour >= 9 && hour <= 15, "Day", 16 && hour <= 23, "Evening", Null )
Push( features, { attributes: { HOUR_OF_CRASH: hour, TOD: tod } })
return FeatureSet( fields, Values, geometry:'' )
Hi @Bec,
var fields = [
var features = [];
for (var f in fs) {
Also note that you can make the When statement more concise
var tod = When(hour >= 0 && hour <= 5, "Night",
hour <= 15, "Day",
Null
Also, very good input from you as well Ken! Thank you for sharing your knowledge and experience.
Yes, RPGIS, your input about returning a FeatureSet was valuable in helping me get to my final output. I made a few more adjustments to the final data expression and what you see below is the working version along with an image of the output.
/// Connect to portal layer
portal,
"d651aa4112e5408ea9a1cfabecd6485c",
23
// Portal layer is a proxy to REST Service layer called CoC Crash Data
// If REST Service layer attributes change may affect data expression
// --- Define Output Schema ---
var fields = [
{ name: "TOD", type: "esriFieldTypeString" },
{ name: "SEVERITY_BY_TYPE_CD", type: "esriFieldTypeString" },
{ name: "CRASH_TYPE_CD", type: "esriFieldTypeString" },
{ name: "DAY_IN_WEEK_CD", type: "esriFieldTypeString" },
{ name: "Month", type: "esriFieldTypeDouble" },
{ name: "HIN", type: "esriFieldTypeSmallInteger" },
{ name: "ODPS_SPEED_IND", type: "esriFieldTypeString" },
{ name: "FUNCTIONAL_CLASS_CD", type: "esriFieldTypeString" },
{ name: "ODOT_LANES_NBR", type: "esriFieldTypeDouble" },
{ name: "ODOT_YOUNG_DRIVER_IND", type: "esriFieldTypeString" },
{ name: "ODPS_SENIOR_DRIVER_IND", type: "esriFieldTypeString" },
{ name: "DISTRACTED_DRIVER_IND", type: "esriFieldTypeString" },
{ name: "WEATHER_COND_CD", type: "esriFieldTypeString" },
{ name: "LIGHT_COND_PRIMARY_CD", type: "esriFieldTypeString" },
{ name: "ROAD_COND_PRIMARY_CD", type: "esriFieldTypeString" },
{ name: "ODOT_CRASH_LOCATION_CD", type: "esriFieldTypeString" }
var features = [];
// --- Build Output Records ---
for (var f in fs) {
var tod = When(
hour >= 16 && hour <= 23, "Evening",
null
Push(features, {
attributes: {
TOD: tod,
SEVERITY_BY_TYPE_CD: f.SEVERITY_BY_TYPE_CD,
CRASH_TYPE_CD: f.CRASH_TYPE_CD,
DAY_IN_WEEK_CD: f.DAY_IN_WEEK_CD,
Month: f.Month,
HIN: f.HIN,
ODPS_SPEED_IND: f.ODPS_SPEED_IND,
FUNCTIONAL_CLASS_CD: f.FUNCTIONAL_CLASS_CD,
ODOT_LANES_NBR: f.ODOT_LANES_NBR,
ODOT_YOUNG_DRIVER_IND: f.ODOT_YOUNG_DRIVER_IND,
ODPS_SENIOR_DRIVER_IND: f.ODPS_SENIOR_DRIVER_IND,
DISTRACTED_DRIVER_IND: f.DISTRACTED_DRIVER_IND,
WEATHER_COND_CD: f.WEATHER_COND_CD,
LIGHT_COND_PRIMARY_CD: f.LIGHT_COND_PRIMARY_CD,
ROAD_COND_PRIMARY_CD: f.ROAD_COND_PRIMARY_CD,
ODOT_CRASH_LOCATION_CD: f.ODOT_CRASH_LOCATION_CD
// --- Return FeatureSet (non-spatial) ---
return FeatureSet({
fields: fields,
features: features
You could go a more programmatic route.
var HRC = "HOUR_OF_CRASH" ; var TODn = "TOD"
var FDict = Dictionary( HRC, "esriFieldTypeInteger", TODn, "esriFieldTypeString" )
var fields = [
{ name: HRC, type: FDict[HRC] },
{ name: TODn, type: FDict[TODn] }
var features = [];
for (var f in fs) {
FDict[HRC] = f.[HRC]
FDict[TODn] = When( hour >= 0 && hour <= 5, "Night", hour <= 8, "Morning", hour <= 15, "Day", hour <= 23, "Evening", Null )
Push( features, { attributes: FDict })
return FeatureSet( fields:fields, features:features, geometry:'' )
