Use a data expression to create a new field based on values in another field for use in a pie chart
1435
11-17-2025 05:32 AM
Bec
Hi!  I'm trying to build a data expression in an ArcGIS Online dashboard that will take a field called, HOUR_OF_CRASH, which is an integer field and not a time field, and populate a new field called, TOD, which will be a text field for the time of day the hour falls within so that the new field can be used to build a pie chart within the dashboard.  The current data expression is shown below.
var portal = Portal("https://www.arcgis.com");
var fs = FeatureSetByPortalItem('d651aa4112e5408ea9a1cfabecd6485c', 23)
// Create schema for the returned FeatureSet
var fields = [
    { name: "HOUR_OF_CRASH", type: "esriFieldTypeInteger" },
    { name: "TOD", type: "esriFieldTypeString" }
var features = [];
for (var f in fs) {
    var hour = f.HOUR_OF_CRASH;
    var tod;
    if (hour >= 0 && hour <= 5){
        tod = "Night";
    } else if (hour >= 6 && hour <= 8){
        tod = "Morning";
    } else if (hour >= 9 && hour <= 15){
        tod = "Day";
    } else if (hour >= 16 && hour <= 23){
        tod = "Evening";
    } else {
        tod = null;
    Push(features, {
        attributes: {
            HOUR_OF_CRASH: hour,
            TOD: tod
Unfortunately, this data expression won't function within the dashboard and doesn't give me quite the output I am looking for in the end.  See the below image of the output.
 My experience with data expression is relatively limited.  Any advice would be greatly appreciated!
Bec
RPGIS
by MVP Regular Contributor
Hi @Bec,
So the issue is that you are not returning a feature. When creating a custom data expression you should return a value similar to the one below.
var fields = [
var features = [];
for (var f in fs) {
    var tod = When( hour >= 0 && hour <= 5, "Night", hour >= 6 && hour <= 8, "Morning", hour >= 9 && hour <= 15, "Day", 16 && hour <= 23, "Evening", Null )
	Push( features, { attributes: { HOUR_OF_CRASH: hour, TOD: tod } })
return FeatureSet( fields, Values, geometry:'' )
RPGIS
Hi @Bec,
var fields = [
var features = [];
for (var f in fs) {
KenBuja
MVP Esteemed Contributor
Also note that you can make the When statement more concise
var tod = When(hour >= 0 && hour <= 5, "Night",
               hour <= 15, "Day",
               Null
Bec
Also, very good input from you as well Ken!  Thank you for sharing your knowledge and experience.
Bec
Yes, RPGIS, your input about returning a FeatureSet was valuable in helping me get to my final output.  I made a few more adjustments to the final data expression and what you see below is the working version along with an image of the output.
/// Connect to portal layer
    portal,
    "d651aa4112e5408ea9a1cfabecd6485c",
    23
// Portal layer is a proxy to REST Service layer called CoC Crash Data
// If REST Service layer attributes change may affect data expression
// --- Define Output Schema ---
var fields = [
    { name: "TOD", type: "esriFieldTypeString" },
    { name: "SEVERITY_BY_TYPE_CD", type: "esriFieldTypeString" },
    { name: "CRASH_TYPE_CD", type: "esriFieldTypeString" },
    { name: "DAY_IN_WEEK_CD", type: "esriFieldTypeString" },
    { name: "Month", type: "esriFieldTypeDouble" },
    { name: "HIN", type: "esriFieldTypeSmallInteger" },
    { name: "ODPS_SPEED_IND", type: "esriFieldTypeString" },
    { name: "FUNCTIONAL_CLASS_CD", type: "esriFieldTypeString" },
    { name: "ODOT_LANES_NBR", type: "esriFieldTypeDouble" },
    { name: "ODOT_YOUNG_DRIVER_IND", type: "esriFieldTypeString" },
    { name: "ODPS_SENIOR_DRIVER_IND", type: "esriFieldTypeString" },
    { name: "DISTRACTED_DRIVER_IND", type: "esriFieldTypeString" },
    { name: "WEATHER_COND_CD", type: "esriFieldTypeString" },
    { name: "LIGHT_COND_PRIMARY_CD", type: "esriFieldTypeString" },
    { name: "ROAD_COND_PRIMARY_CD", type: "esriFieldTypeString" },
    { name: "ODOT_CRASH_LOCATION_CD", type: "esriFieldTypeString" }
var features = [];
// --- Build Output Records ---
for (var f in fs) {
    var tod = When(
        hour >= 16 && hour <= 23, "Evening",
        null
    Push(features, {
        attributes: {
            TOD: tod,
            SEVERITY_BY_TYPE_CD: f.SEVERITY_BY_TYPE_CD,
            CRASH_TYPE_CD: f.CRASH_TYPE_CD,
            DAY_IN_WEEK_CD: f.DAY_IN_WEEK_CD,
            Month: f.Month,
            HIN: f.HIN,
            ODPS_SPEED_IND: f.ODPS_SPEED_IND,
            FUNCTIONAL_CLASS_CD: f.FUNCTIONAL_CLASS_CD,
            ODOT_LANES_NBR: f.ODOT_LANES_NBR,
            ODOT_YOUNG_DRIVER_IND: f.ODOT_YOUNG_DRIVER_IND,
            ODPS_SENIOR_DRIVER_IND: f.ODPS_SENIOR_DRIVER_IND,
            DISTRACTED_DRIVER_IND: f.DISTRACTED_DRIVER_IND,
            WEATHER_COND_CD: f.WEATHER_COND_CD,
            LIGHT_COND_PRIMARY_CD: f.LIGHT_COND_PRIMARY_CD,
            ROAD_COND_PRIMARY_CD: f.ROAD_COND_PRIMARY_CD,
            ODOT_CRASH_LOCATION_CD: f.ODOT_CRASH_LOCATION_CD
// --- Return FeatureSet (non-spatial) ---
return FeatureSet({
    fields: fields,
    features: features
RPGIS
You could go a more programmatic route.
var HRC = "HOUR_OF_CRASH" ; var TODn = "TOD"
var FDict = Dictionary( HRC, "esriFieldTypeInteger", TODn, "esriFieldTypeString" )
var fields = [
    { name: HRC, type: FDict[HRC] },
    { name: TODn, type: FDict[TODn] }
var features = [];
for (var f in fs) {
    FDict[HRC] = f.[HRC]
    FDict[TODn] = When( hour >= 0 && hour <= 5, "Night", hour <= 8, "Morning", hour <= 15, "Day", hour <= 23, "Evening", Null )
 	Push( features, { attributes: FDict })
return FeatureSet( fields:fields, features:features, geometry:'' )
