Unwanted scrollbars in rich text element
2864
7
05-27-2022 08:41 AM
RandyMcGregor3
I have a (very) simple graphic loaded into a rich text element. When the dashboard is on a smaller screen, a scrollbar shows up on the right side. Is there any way to get this image dynamically change size? This scrollbar is quite unsightly.
Thank you
RandyMcGregor3
Scrollbars show up a lot - for example, I use rich text elements or lists for single line input. A scrollbar is never desirable, there's only one line and scrolling is not something that makes sense. Is there any way to turn it off or make the elements automatically resize?
Thank you,
Randy McGregor
RobertBorchert
Honored Contributor
the scroll bar shows up when you items in the box will not fit in the box. So the scroll bar shows up to the user can see it all.
First check to make sure the smaller screen viewer has Scale and Layout set to 100% Recommended
Adjust the dimensions of your image to be the same ration as the window in which of the rich text element
RandyMcGregor3
Thanks Robert,
Sorry, but what does, 'make sure the smaller screen viewer has Scale and Layout set to 100% Recommended' mean? Not sure which setting that refers to.
Thanks for your help,
Randy
RobertBorchert
Honored Contributor
Right click on your desktop.
Select Display Settings
for each monitor or display you can select one and scroll down a little bit
Where is shows Scale and Layout
Change the size of text, app, and other items.
Below that is a drop down menu.
Often people will change that from 100% to something different so things will appear bigger.
RandyMcGregor3
Thanks. That helps, but I don't have control over all the monitors that will view the dashboard. I think this may be a built in limitation? I know that indicators automatically resize text - They rarely have scroll bars because text resizes based on available space. I may see if I can get that to work.
RobertBorchert
Honored Contributor
Also check the display settings on the computer designing the dashboard and ensure it is at 100%
Also, the smaller screen user may have set the resolution really low to make things bigger as well.
RobertBorchert
Honored Contributor
probably your only solution will be to tell people when they complain about scroll bars what they need to do to fix it.
I have created a number of dashboards and have a lot of people calling because it does not look right.  and the answer is that setting.  Your other option may be to design a dashboard for each of the display settings
