The "Layer not accessible" issue
3996
02-10-2021 01:48 PM
Alexander_Valchyshen
I have created a map with a featured layer. Then, I started creating a dashboard and placed a map with this layer. The problem is that if I started creating a list or other element (chart) the data in the featured layer is not accessible as this error is reported every time that this "Layer not accessible".
What am I doing in a wrong way?
Thank you very much!
Tags (3)
DavinWalker2
Are you able to send any screenshots or other information regarding the error. Just a stab in the dark ss this layer is a secured service do you have login credentials to access it?
Hi, thanks for your support!
I am attaching the screenshot of my ArcGIS online dashboard action, when I am trying to add, say, a chart. The label "Layer not accessible" appears against the layer within an embedded map.
Yesterday, after making my initial post here I found that I can use the same layer, which appears at the bottom of such window -- and indeed I succeeded of creating a desired list.
DavinWalker2
Good to hear you got it working.
