Test execution error: Unknown Error. Verify test data.
1885
02-14-2025 06:13 AM
PlANNADMIN
Hello,
I'm trying to create a feature set as the source for a table element, but my data expression gives the following error: 'Test execution error: Unknown Error. Verify test data.' I would greatly appreciate any help available. I'm very new to Arcade.
KenBuja
MVP Esteemed Contributor
Your error comes from lines 14 and 15, where you need "esriFieldTypeString" instead of "esrifieldTypeString". Case matters!
var portal = Portal('https://www.arcgis.com/');
var fs = FeatureSetByPortalItem(
    portal,
    '7bd678181312462faebc8d1077f8fc3a',
    0,
        'service'
    false
var fsDict = {
  'fields': [
    {'name': 'service_type', 'alias': 'Type of Service', 'type': 'esriFieldTypeString'},
    {'name': 'revenue', 'alias': 'Revenue', 'type': 'esriFieldTypeString'}
  'geometryType': 'esriGeometryNull',
  'features': []
var i = 0;
for (var f in fs) {
  var income = IIF(f['service'] == "reinstallation", 150, 200)
  fsDict.features [i++] = {
    'attributes': {
      'service_type': f.service,
      'revenue': income
Console(fsDict.features)
return FeatureSet(fsDict)
KenBuja
Can you post this as code instead of an image? It's easier to do checking when we can copy the code to the Playground
PlANNADMIN
Thank you so much for responding. The code is below:
    portal,
    0,
        'service'
    false
var fsDict = {
  'fields': [
    {'name': 'service_type', 'alias': 'Type of Service', 'type': 'esrifieldTypeString'},
    {'name': 'revenue', 'alias': 'Revenue', 'type': 'esrifieldTypeString'}
  'features': []
var i = 0;
for (var f in fs) {
    'attributes': {
      'revenue': income
KenBuja
    portal,
    0,
        'service'
    false
var fsDict = {
  'fields': [
  'features': []
var i = 0;
for (var f in fs) {
    'attributes': {
      'revenue': income
PlANNADMIN
Thank you so much! It works perfectly now. I really appreciate your help.
