Table field disappearing
1323
09-12-2024 09:40 AM
lmarun
Hello,
I have a dashboard that is returning a list of open grants, each of which includes information such as funder, grant amount, eligibility, etc.
One field is due_date. Some of the grants are rolling/ongoing, so I've run into a problem posted in various place on the ArcGIS forum, being that even though I have that field designated as 'text', ArcGIS converts not only converts the dates (written as text) into dates, but also ignores the fields that have 'Rolling/Ongoing' and converts them to null.
In addition, while I can see the due_date field in the table uploaded to ArcGIS, that field disappears when I try to refer to it in the dashboard.
Does anyone have any suggestions (even though I haven't found any solutions per similiar past posts) to the first, main problem of the transformation of dates written as text? Hopefully, this will prevent the second issue of that missing field in Dashboards as well.
Thanks!
lmarun
I found an easy workaround. I simply added a space in front of all of the dates.
I hope this helps someone else! 🙂
lmarun
