Summery Widget in the web dashboard not working.
12783
18
04-15-2016 08:33 AM
ThomasFurcron
When viewing the summery widget in the web dashboard all i see is "No Data", but when viewed in the windows application it comes up correctly.  Is there a known issue with the summary widget in the web viewer?
thanks for any help or suggestions.
Tom
JuanOrozco
I am having the exact same issue. Some widgets work and some don't. I found this link, towards the bottom it says "Not all of the widgets available in the Windows version are in the Browser version. We are working to reach parity between the platforms with a set of focused releases between now and July."
Operations Dashboard in a browser | ArcGIS Blog
Good luck.
ChristopherOlsen
Hi Juan,
This link is a blog when Operations Dashboard first released the web version in 2014 and any all of the widgets should be performing the same now.  I'm looking into the bug that Juan mentioned below.
Chris
JuanLuera
Hola Tom y Juan,
This is Juan of Support Services, and this is a logged bug within our system and our developers have been made aware of this issue. We appreciate you both posting this and bringing this to our attentions, and I am including the bug information for you both. You can always reach out to us in Support Services for an update on the status of this bug. Thanks, Tom y Juan!
BUG-000094326 - The browser version of the Operations Dashboard for ArcGIS (Desktop version) returns no data for the Summary widget.
Staus: New
Juan
AliBarakat
hello,
Im also facing the same issue, its not just with the summary widget, i guess the problem is from the map service it self.
Did you guys find a solution for this?
im using a mapservice not a feature service
im using portal 10.3.1, sql server 2012
my data isnt versioned
Also its been 2 weeks that im facing a weird behavior of the windows dashboard.
Everytime i try to add the query widget, the dashboard gives me ana error and closes.
also adding christopher Christopher Olsen
Thank you guys.
LSaunders
Any idea of when this might be fixed?  We should be able to expect that our dashboards will show correctly in the browser when we publish them. I have this issue with the summary widget and the indicator widget.
Thanks!
ChristopherOlsen
Is it that the count shows null or that the count is different?  What does the indicator widget look like?
LSaunders
the widget shows nothing at all for the summary and indicatorscreencapture.jpg. See attached image.
ChristopherOlsen
Hi Leah-
I dug a little deeper on this and there was a bug with Server that was fixed at 10.4- specifically, the outStatistics query of a MapServer returns incorrect results when the dataset is non-versioned archived data.  What version of server are you using?
Chris
LSaunders
I'm on 10.4.  This is a not GIS data, but a query layer from a production Oracle database (non-spatial).
