Statistics across multiple datasets?
2054
04-29-2019 11:10 AM
AndrewHargreaves2
Hello Operations Dashboard for ArcGIS‌ team,
Is there a way to add more than one data source to each widget? I'm looking for counts of features across multiple datasets.
Thanks
DerekLaw
Esri Esteemed Contributor
Hi Andrew,
Can you please be more specific and describe your workflow in more detail? Which element? What exactly do you want to do?
Thanks
AndrewHargreaves2
Hi Derek
We have three (point) layers. Within the three there are some shared field names and some unique field names. I'd like statistics such as:
  • total count across all three datasets
  • sum of filtered values (from those shared field names across all three)
  • ave of filtered values (from those shared field names across all three)
The most obvious widget candidates are:
  • Indicators
  • Gauges
I'm basically asking for is the ability to add more than a single datasource - though I know that'll be tough to implement.
DerekLaw
Thanks for the detailed use case Andrew, I appreciate it. Let me check into this further.
