Starting Indicator with no value or zero as a value
1500
09-25-2024 04:30 PM
TAMRAO_HALLORAN
Good afternoon-
       I have an indicator in a Dashboard whose display shows with a select within a map. When I launch the dashboard the display has a value in it even though nothing within the map is selected. How do I set-up the indicator so that nothing is displayed or  text indicating that they should select a point on the map is displayed?  If they clear their selection or refresh the page I would like the indicator to default to this preset value.
     Tamra O'Halloran
JenniferAcunto
Set the indicator to only render when filtered.
Then set a custom No Selection message in the Indicator > General Settings.
- Jen
JenniferAcunto
- Jen
