Stacked Indicator Navigation
382
06-29-2026 11:30 AM
EvanTimms
In the last update, dashboards seem to have altered the navigation for moving through stacked indicators. Is this something we can change? From a UI perspective, the side scrolling is not very intuitive, especially when the refresh button is covering an indicator in the bottom right of the dashboard.
Michael_Dykes
To add to this I'm unable scroll to the last item in my stack in this stack of indicators (at the bottom right corner of my dashboard) in the editor (I'm trying to edit the text that is displayed):
There is no reset button active in this dashboard at the moment so it's not interfering.
Here it is in the live dashboard (not in the editor mode):
Michael_Dykes
As well, some stacked indicator elements when I get to the end of the tabs the icon turns grey, but for some it remains white and the text is cut-off in the tab display name:
(Update): It seems like there is a character limit horizontally in the stack display name/scroll area. I was able to update the final indicator's display name by removing characters from the 2nd to last indicator's display name.
erica_poisson
We did some testing around this, and the new scrolling experience is extremely clunky and required more clicks than necessary. That said, it did actually seem to work well with keyboard navigation. However, this is not something most users would try, should know how to try, or be expected to do. This behavior should be improved.
Erica
dkutkevicius_hb
New scrolling experience could definitely be improved. In addition to using the navigation arrows, either with the keyboard or mouse, I would suggest trying the Shift + mouse wheel shortcut. I have found it partially similar to previous dropdown tab list.
