Show Attachment Count per Record in Dashboard List
1205
02-03-2025 07:55 PM
JustinWolff
I've discovered the hard way that the Arcade function Count(Attachments($feature)) cannot be used in a Field Maps Calculated Expression to automatically update and return a count of the attachments, because the attachments can't be counted until the record is submitted.  Fine.  Is there a way to display the number of attachments per record in a Dashboard List?  I cannot figure out how to make this work.  I'm doing all of this in AGO using hosted data.
Any chance @jcarlson has done something like this?
Thanks
AndreasHall
I do not know exactly how but you could try to use arcade in the list element to count the number of attachments per record. Perhaps Count(Attachments($feature)) will work?
JustinWolff
Thanks @AndreasHall - I've have an indicator to give me total attachments (see below), but I just need a list with a count for every feature/record.  I'm drawing a blank today...
var portal = Portal('https://------.maps.arcgis.com');
var assets = FeatureSetByPortalItem(
    portal,
    'item_id',
    0,
    false
var photo_count = 0
for(var feat in assets){
  photo_count += Count(Attachments(feat))
return photo_count
