Series Smoothed Line Chart
932
7
02-04-2026 10:11 AM
MyEthiopia
Hi All,
Is it possible to remove just 0 labels from my line chart that is based on time/date. I want to total count label to be visible but remove 0's from the chart as well as the same between the different peaks.
AdrianWelsh
MVP Honored Contributor
What happens if you do a filter for those values (where the value does not equal 0)? Does it truncate your chart in a way that does not look good?
MyEthiopia
Thanks @AdrianWelsh No change unfortunately, is it because it's a date field?
AdrianWelsh
Possibly so. Can you change the value of the 0 to a null value, therefore nothing should show up?
MyEthiopia
Did that nothing changed. To explain further the 0 values don't exist within the data, that's where I am having trouble filtering it out.
AdrianWelsh
Hmm, maybe I am not understanding the data very well. I notice that if I try this with some data that I have, it shows me a 'count' of all points that occurred on those dates. This is how it looks natively (similar to yours, except it shows a '1' instead of a 0).
But if  I choose Parse Dates, it looks a little more spread out
Maybe that could work in yours?
MyEthiopia
I am using hour instead of day. And my data is aggregated using data expression. Instead of the manually populated date/time field (there was a date formatting issue). I am using the creation date field.
MyEthiopia
@AdrianWelsh Thank you for troubleshooting with me. My end users didn't complain but I would love to see it cleaned up.
