Sending parameters between dashboards
1505
12-06-2023 03:39 AM
Luís_Baptista
Hi, y'all
I'm trying to send parameters between a main dashboard and an embedded dashboard. The purpose is for the embedded dashboard update the info when I select something in the main dashboard.
As soon as I embed the dashboard, the information in the embedded is filtered according to the first element of the table.
Exº: If one parameter filters by sex, the embedded dashbord appears with the filter related to the first element in the table (male or female).
How can i configure it to all information be displayed when no selection is active in the main dashboard?
AdrianWelsh
MVP Honored Contributor
@Luís_Baptista , did you find an answer to this?
Luís_Baptista
Hi, Adrian. Thank you for your reply.
In part, yes. I can send it from one dashboard (A) to each widget in a second dashboard (B). However, if nothing is selected in A, nothing is showed in B.
I wanted to see everything in B and, when something is selected in A, the widgets update in B.
There are any way to do this? Any kind of definition to show all when nothing is selected?
Thanks
AdrianWelsh
Luis, I am not seeing a way to be able to do this but that is the extent of my knowledge. How did you get the parameters from dashboard A to populate into dashboard B?
