Searching within a Dashboard table element
997
01-02-2026 10:41 AM
Ellie_Linden
Is there currently a way for a Dashboard user to search within a table element? If not, is this a planned update? I recognize that the table could be filtered with a selector and user can search within List element, but neither of those options work in our case.
Tags (3)
VenkataKondepati
Honored Contributor
No. Dashboards do not currently support in-table search within the table element itself.
The table widget lets users sort and filter (via selectors and actions), but there’s no built-in text search box like you see in the List widget or in the Map Viewer’s attribute table.
At this time, the only ways people work around it are:
  • Add a filter widget or selector that narrows the table dynamically
  • Use a List with search enabled (if that UX fits your use case)
  • Build a custom Experience/React app that uses the API and adds a real search input
As of now, there’s no native planned update from ESRI that adds a search bar directly to the Dashboard table element, this limitation has been confirmed by users and product feedback channels.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
Ellie_Linden
Thanks very much for the information, much appreciated.
