Script runs on test, but displays a table with no values
1697
07-12-2024 04:08 AM
MarceloCatalão
Hello
I wanted that in a dashboard list I am presented with the Date of the last record of a certain value and 3 days are added to the date, strange is that there is no script error, sample me a table, but without the desired final values, what can be the problem?
Thanks
// Get the Item Portal FeatureSet
var fs = FeatureSetByPortalItem(Portal('https://sgmai.maps.arcgis.com'), 'cc483edaa0f3457c8cd99149d36c1ced', 0, ['selec', 'CreationDate'], false);
// Filter AEO records and sort by creation date
var fsAEO = Filter(fs, "selec = 'AEO'");
var sortedFS = OrderBy(fsAEO, 'CreationDate DESC');
// Create a list to store the modified records
var updatedFeatures = [];
// Iterate over the records and modify the date
for (var feature in sortedFS) {
// Obter a data de criação
var creationDate = Date(feature.CreationDate);
// Add 3 days to the date
var newDate = DateAdd(creationDate, 3, 'days');
// Create a New Object with the Date Modified
var updatedFeature = {
'attributes': {
'selec': feature.selec,
'CreationDate': newDate
// Add the new object to the list
Push(updatedFeatures, updatedFeature);
// Create a New FeatureSet with the Modified Records
var updatedFeatureSet = {
'fields': [
{'name': 'selec', 'type': 'esriFieldTypeString'},
{'name': 'CreationDate', 'type': 'esriFieldTypeDate'}
'geometryType': '',
'features': updatedFeatures
// Return the Modified FeatureSet
return FeatureSet(Text(updatedFeatureSet));
MarceloCatalão
Resolvido: Este funciona 🙂
Muito obrigado
// Fetches features from a public portal item
  // portal item id
  "cc483edaa0f3457c8cd99149d36c1ced",
  0, // layer id
  ['selec', 'PGDH2'], // fields to include
  false // include or exclude geometry
// Filter AEO records and sort by 'PGDH2' descending
var fsAEO = Filter(fs, "selec = 'Registar AEO'");
console("Count of filtered AEO records: " + Count(fsAEO));
var sortedFS = OrderBy(fsAEO, "PGDH2 DESC");
  // Get the PGDH2 date and convert to string to remove time
  var creationDate = Text(Date(feature.PGDH2), "YYYY-MM-DD");
  // Convert back to date object and add 3 days
  var newDate = DateAdd(Date(creationDate), 3, "days");
  // Format new date to only include day, month, and year
  var formattedDate = Text(newDate, "DD-MM-YYYY");
  // Create a new object with the date modified as text
    attributes: { selec: feature.selec, PGDH2: formattedDate }
// Create a new FeatureSet with the modified records
  fields: [
    { name: "selec", type: "esriFieldTypeString" },
    { name: "PGDH2", type: "esriFieldTypeString" }
  geometryType: "",
  features: updatedFeatures
// Log the updated feature set
console("Updated feature set: " + Text(updatedFeatureSet));
// Return the modified FeatureSet
return FeatureSet(updatedFeatureSet);
KenBuja
MVP Esteemed Contributor
Your code works correctly with a sample dataset (with a couple of modification for different fields). I would check if you're getting the expected records from your filter (line 13).
  Portal("https://www.arcgis.com"),
  // portal item id
  "6200db0b80de4341ae8ee2b62d606e67",
  0, // layer id
  ["*"], // fields to include
var fsAEO = Filter(fs, "FeatureCode = 1000");
console(Count(fsAEO))
var sortedFS = OrderBy(fsAEO, "LASTUPDATE DESC");
  var creationDate = Date(feature.LASTUPDATE);
  var newDate = DateAdd(creationDate, 3, "days");
    attributes: { selec: feature.FeatureCode, CreationDate: newDate }
  fields: [
    { name: "CreationDate", type: "esriFieldTypeDate" }
  geometryType: "",
MarceloCatalão
Your data is working fine, when I change it to my portal and go to put the value "Register AEO" it gives an error
(ERRO: Test execution error: Expected "!=", "(", "*", "+", "-", "/", "<", "<=", "<>", "=", ">", ">=", "AND", "OR", "||", [ \t\n\r], or end of input but "A" found.. Verify test data.)
  // portal item id
  0, // layer id
  ['selec','CreationDate'], // fields to include
var fsAEO = Filter(fs, "FeatureCode = Registar AEO");
var sortedFS = OrderBy(fsAEO, "selec");
  fields: [
  geometryType: "",
KenBuja
The Filter sql statement is incorrect. You had it correct in your original code. Did you mean to use this?
MarceloCatalão
Muito obrigado
  // portal item id
  0, // layer id
  fields: [
  geometryType: "",
dgiersz_cuyahoga
I suggest adding Console() statements after each variable declaration to make sure they are returning what you are expecting. Console() can show the object returned and you can also use it to show a count of objects.
#CLE #sloth
