Time in Dashboard lists
989
07-31-2023 09:19 AM
ChrisTruty
I have a dashboard list that is attached to a map point layer.  When formatting the list template line, I use the dropdown menu to select the attribute field to display in the list.  However, when selecting a date field that includes time, the time does not display on the line only the date.  Following some online advice, I looked in the map viewer and displayed the point attributes and the time is displayed there.  It's only in the Dashboard list widget that times are not displayed.  Am I missing something in how this should be displaying?
Chris
Tags (1)
msevierTPCHD
Did you ever find a resolution to this?  I'm having the same issue.
