Scaling rich text elements in Operations Dashboards
1924
04-29-2020 02:42 PM
Mary_GermanWhitley
Is there any magic HTML code I can use in a Rich text box in Operations Dashboard, so the text scales the same way the indicators do? I have a mix of indicators and static text 'statistics' side by side. I can get them pretty close in the editor, but of course as soon as the screen size changes, things go squirrelly. "As the indicator is resized, the text displayed in the top, middle, and bottom areas scales to fit the size of the indicator."
mthompson
Same question. The text in a Rich Text widget does not scale while the text and numbers in an Indicator widget do. It would be nice if they would act the same way.
richardthomson
I haven't found a way to get this to work with Rich Text. However, a potential workaround is just to use the indicators themselves. Set the indicator type to feature, only display 1 value, then just get rid of any text that draws the selected data source in the indicator tab and make it static text. I use this to handle headings.
