Return non-used domain values in Dashboard List
1013
02-18-2022 09:24 AM
JeffMiller7
Good day all!
I have a dashboard set up that summarizes the current status of ongoing construction projects.  In my projects layer, I have a field for Inspector, which references a domain list consisting of all available inspectors.  I am attempting to set up a list widget that lists all of the available inspectors found within that domain that are not currently assigned to a project.  I have played around with the domain function in Arcade, but seem to be having trouble getting it to work properly.
I am curious if this is even a possibility, but I thought I would throw it out there to see if anyone had ever attempted something similar.  Any input you could provide would be most welcomed!
HuubZwart
This should be possible using a combination of the FeatureSetByPortalItem (or any of the other FeatureSet functions) and Schema. Schema allows you to get all of the coded domain values via the fields/domain properties.
Something like this:
var somelist = []
function myfilter(someval){
    return indexOf(somelist, someval) == -1
var coded_values = Schema($feature)['fields'][4]['domain']['codedValues']
for(var i in coded_values){
    Push(somelist, coded_values[i]['name'])
var fs = FeatureSetByPortalItem(Portal('PORTALURL'), "ITEMID", LYR_INDEX)
var in_use_list = []
for(var f in fs){
    Push(in_use_list, f.FIELDNAME)
return Filter(in_use_list, myfilter)
HuubZwart
var somelist = []
for(var f in fs){
