Reliability of Dashboard URL Parameters
1367
08-16-2023 11:59 AM
ChelseaRozek
MVP Regular Contributor
I'm trying to use a feature URL parameter for the ObjectID in my AGO Dashboard, but it only loads properly for 1/10 tries. Has anyone else had this issue? As it does occasionally load, I know it's set up properly. I do have a ticket in with ESRI, but I'm hoping to hear if others have experienced this as well. I've tried across browsers and computers and clearing my cache, yet I cannot find a scenario that reliably works. I've confirmed that the OID I'm testing does in fact exist.
SandraCHayden
I am having issues with dashboard url parameters too.
Did you get any help from ESRI?
ChelseaRozek
Hi @SandraCHayden ! Are you having the same issue with it only loading some of the time? We didn't get it to work 100% of the time, but there was some improvement when I really tried to cut back on what needed to load in the app: Removed unnecessary layers in the map, set better visibility by zoom level, used vector basemaps, used vector symbology on points, reduced the photos showing in my "photo gallery" dashboard widget, cleaned up the popups to make them more efficient (they have lots of arcade), etc....
