Relative to Current Time - Map and Layer Filters - will not work
3950
10-04-2013 09:41 AM
PerryClark
I cannot get the "relative to current time"  map filters and layer filters to work.
Example filter: ???DateDue Less than or equal The next 1 Months???
If you apply a layer filter as shown above, the map does not change and a warning icon is displayed on the widgets, when I click the warning it states:
???The following data sources are not accessible
Invalid service or the service is not available.
http://.......???
When you click on the link in the above error it takes you to the rest endpoint ??? no problem
The following does work:
  1. Filters that use relative to current time options work when used with the query widget (the example in the problem statement above works when applied in a query widget)
  2. Map and layer filters that use explicit dates, example:  DateDue Greater than or equal 10/04/2013 00:00:00
  3. All non-date Map and Layer filters
I am using secure 10.2 Services hosted on our server.
Perry
Kylie
by Esri Regular Contributor
Hi Perry -- You are right; that is a bug in the current version of the app. It is fixed in the next version.
Kylie
Esri Education Team
