Reassign display text in table using advanced formatting (remove underscores)
2660
02-15-2024 07:23 AM
dwold
I would like to change the display text in a table. Currently, my values have underscores. I would like to remove those underscores so it is cleaner on the table. I am new to arcade but I believe I need to assign a variable and change the text values there and then call that variable in the displayText line?
@JenniferAcunto
@IssyAmis
@AdrianWelsh
JenniferAcunto
Yes. You are on the right track. You will want to use the Replace function to search for _ and replace it with a space.
var prettytext = Replace($datapoint.core_capability, '_', ' ')
In the below example, my data has commas instead of an underscore, but the basic principle is the same.
- Jen
AdrianWelsh
MVP Honored Contributor
I have used the Replace function in Arcade to replace my underscores for spaces (at least in a popup window). I think it should work for a table too. Here is an example:
https://support.esri.com/en-us/knowledge-base/how-to-replace-values-of-a-field-using-an-arcade-expre...
And this is the developer site for the function itself: https://developers.arcgis.com/arcade/function-reference/text_functions/#replace
dwold
@AdrianWelsh thanks for the tip!!
JenniferAcunto
- Jen
dwold
@JenniferAcunto thank you!!!!
