Problem with putting multiple selectors on the dashboard; the second selector does not work
2699
08-18-2022 02:16 AM
RyokoAraki
Hello, I have a problem with putting multiple selectors on the ArcGIS Online dashboard.
[Situation]
On the ArcGIS Online dashboard edit page, I put two selectors that filter points based on grouped values (as in Capture.PNG). Both selectors filter data from the same layer. Multiple selections are allowed.
[Problem]
The first selector works without problem. However, the second selector does not work displaying "no options available"  (as in Capture0.PNG) both in the edit and view pages. When I go to the edit page and the tab Configurations > Actions on that filter, it also says "Element does not support any events."
[Solutions I tried (but did not work)]
- Recreating the selector
- Putting the third selector
- Dis- & en-abling the rendering actions on the first selector
Thanks for your help in advance!!
RyokoAraki
Hi, adding "category field" in addition to the filters worked out and solved this problem, but I still do not understand why, so I appreciate if anyone has ideas.
