Printing map and widgets from Operations Dashboard view
9501
08-07-2013 03:08 PM
JakeMatthys
Has anyone developed an addin that will allow a user to the dashboard map view as well as including the various widgets as objects in the map layout?  I noticed this addin on arcgis.com (http://www.arcgis.com/home/item.html?id=c3d3316d12f145369e2ad603cd7e9876) but it doesn't appear to be functional?
  - Jake
TifPun
Hi Jake,
There is another addin in arcgis.com: http://www.arcgis.com/home/item.html?id=c3d3316d12f145369e2ad603cd7e9876. It is a map tool and you can optionally include header/footer/legend etc into the map to print.
Tif
CharlemagneLosaria2
the links point to the same add-in but it's greyed out
CarolGhostine
An addin cannot be downloaded directly from ArcGIS Online.
1. Sign into Operations Dashboard (need to have publisher/admin access to make the following changes)
2. Click on Tools, Edit operations view. You will see the "Widgets" menu.
3. Click on Manage Add-ins
4. Click on Add
5. Search for "Print Map"; make sure the search results is filtered by "All Results"
6. Select the Print Map OperationsDashboard AddIn
7. Back on your map. Click the map tools gear and select the print tool.
Carol
MickeyZolezio1
I hate to revive a dead post, but the printing add in kills the dashboard application I've been working on. Is anyone else out there stumbling upon this thread and trying to use the Print add in?
CharlemagneLosaria2
Thanks for the Reply Carol this helped me a lot.
Back to the original question of the thread starter, He is asking if there is a way to include in the print out the widgets such as the guage or bar graph or pie etc hmmm
4. Click on Add
Carol
