Predefined Date Selector issues
939
09-29-2025 04:34 PM
Labels (2)
amarcz_cc
Hello,
I am attempting to run a simple Select a Date using the predefined values of [Show All, Today, Future] and can not for the life of me get the Today query to work.
My data is in a date datatype, but comes in two fields of StartDate & EndDate. Using the Today, Within the Last [1 Day], or Within the Next [1 Day] query all the features out.
I don't understand what I am missing.
Data is published to my Enterprise Portal, then using a Collaboration, shared to ArcGIS Online where the Dashboard is being created.
Nora-Schaak
Do you have a screenshot of your pre-defined date configuration? This might help the community suggest alternative settings.
Maybe there's a standing bug logged with that data convenyance method: Portal/AGOL Collaborative Sharing. However, out of some initial searches I did not find anything specific.
ArcGIS Online Technical Support | Esri
Esri Support Search Results (ArcGIS Dashboard Bug Search)
amarcz_cc
That's what I am trying to figure out, how can I achieve a Predefined Date Selector of Today, when using two fields? Fields are StartDate& EndDate.
Neal_t_k
MVP Regular Contributor
@amarcz_cc Is there a particular reason you want to use 2 dates?  Why not just use one of your two dates or CreationDate (when the form was submitted).
amarcz_cc
The dates signify the extent of the Project. When setting up the Time Selector Actions, I chose to use start date, but was getting the same issues as stated above.
For example, I expect to see the following:
Show All: Show all Projects
Today: Show Projects that are between Start Date & End Date
Future: Show projects that have not started today, but are yet to come.
It is the Today selector I am having the issues with.
Neal_t_k
Have you considered a status field and a category selector instead of based on dates?
