Portal Dashboard - "No elements supporting actions yet" when map layer is Map Image Layer
6274
10
05-04-2022 04:02 PM
DarinaTchountcheva
Portal for ArcGIS 10.8.1
Layer is published from ArcGIS Pro 2.7. Over 100K records.
If I add a map with a Map Image Layer to the dashboard and then add a chart. I can't add the map image layer as a target in the Chart actions. It displays "No elements supporting actions yet" .This is valid for any other elements.
I need to use Map Image Layer as the data is huge and this is the only layer type that would draw fast enough.
What do I need to do be able to use the layer in the Action targets in a dashboard elements.
Thank you!
Darina
DarinaTchountcheva
Josh,
Just wanted to let you know that I was able to use a Map Image Layer in ArcGIS Online. It worked perfectly and performance is great.
Darina
