Polygon centroid rendering in Ops Dashboard
4218
03-17-2015 04:49 AM
JeffPires3
My polygon layer in a web map is using the "Counts and Amounts" symbology, and it appears as expected in the web map, with points at the polygon centroids, and the point sizes dependent on an attribute value.  However, when the same web maps is viewed in Ops Dashboard, it looks like it's trying to draw all polygon vertexes with my point symbol, instead of using the centroid.  Has anyone else experienced or solved this?  Thanks!
ChristopherOlsen
Hi Jeff,
This is a known bug / limitation at this time.  Once we have a fix in place, I'll post it on this thread.
Chris
