Pie Chart Dashboard Font
3226
6
03-12-2020 02:41 PM
EmilyL
Hello,
Is there a way to change the text font size and specify the number of decimals shown on the pie chart in Operations Dashboard please?
Thank you,
Emily
Tags (3)
DerekLaw
Esri Esteemed Contributor
Hi Emily,
> Is there a way to change the text font size and specify the number of decimals shown on the pie chart in Operations Dashboard ...
Yes, these options can be set in the Pie Chart configuration panel > Chart > Chart Options
There is a font size parameter and under Formatting > Value.
Hope this helps,
EmilyLee2
Derek,
Thank you very much for your reply.
I don't see your option, is it because I'm using the Portal version?
Thank you,
Emily
DerekLaw
Hi Emily,
That might be the case. What release of ArcGIS Enterprise (Portal for ArcGIS component) are you using? It could be you're using an older/earlier Operations Dashboard release.
Hope this helps,
EmilyLee2
You’re right Derek. I’m using ArcGIS Enterprise 10.6.1. Upgrading ArcGIS Enterprise would require the entire setup of Portal, web adaptors, Data Store, federating, SQL and Windows authentication again, right? It’s not a simple upgrade as ArcGIS desktop or ArcGIS Pro, correct?
Thanks again,
Emily
DerekLaw
Hi Emily,
Correct. You would have to update the entire ArcGIS Enterprise stack to get the updated Operations Dashboard release.
FYI: Possible workaround, you could share your web services from ArcGIS Enterprise to an ArcGIS Online organization, then use Operations Dashboard in the organization.
Hope this helps,
EmilyLee2
We will need to plan out more things in order to upgrade ArcGIS Enterprise task then.
Thanks for the workaround. It’s a good idea, but we have limited ArcGIS Online seats and the dashboard is not for public view.
Thanks a lot of your replies and help, Derek!
-Emily
