Parse data from dashboard element to Survey123 form
1014
01-05-2026 08:09 AM
SCB
Hello!
I'm wondering if it is at all possible to select a feature in a dashboard list and dynamically parse some information from the feature into a Survey123 form that is within an embedded content element within the same dashboard.
Cheers
SCB
VenkataKondepati
Honored Contributor
Yes, and you don't even need custom code to do it. You just have to use URL Parameters to pass data from your List to the Embedded Content element. In your Dashboard, set the Embedded Content URL to the Survey123 web form link and append your fields using the field:SurveyColumn={LayerField} syntax. When you select a feature in your list, the Dashboard "injects" that feature's attributes into the URL, effectively auto-filling the survey on the fly. Just make sure your List has a Filter Action targeting the Embedded Content element so it knows to reload the form whenever you switch features.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
VenkataKondepati
Honored Contributor
Regards,
Venkat
Neal_t_k
MVP Regular Contributor
SCB
Thanks @VenkataKondepati , @Neal_t_k .
I had been exploring this route after reading that blog but was not getting any results.  You pushed me to keep trying this avenue and I realised I needed field:SurveyColumn={field/LayerField}.
Many thanks once again, this has made me very happy 😀
Cheers
SCB
SCB
And just an aside.  I've decided to implement this from selecting a feature in a map rather than from a list.  For anybody wanting to do it that way it is exactly the same set-up but obviously you place the action on a layer in a map rather than in the list element.
Cheers
SCB
