other elements does not filtered when the map extent changed
646
06-09-2022 12:41 AM
frhilyana_geo11
Hi all,
When I zoom in and zoom out my map, it does not filter other elements.
Here is the screenshot of it. The indicator should display only 5 counts.
I've set the map actions to filter the indicator when the extent changed.
Here are other details:-
  • I'm using ArcGIS Enterprise 10.9
  • The data is a feature layer (non-hosted).
  • It needs to be updated daily, so I've set the layer to be 'Referenced' to the server when publishing it to the portal.
Kindly seeking advice on this matter.
