Operations dashboard Utility
2543
01-25-2017 10:38 PM
AliBarakat
Hello,
I have 2 portal installed on 2 different servers.
and i need an operations dashboard on my laptop that i can use for both portals.
I am working offline.
I run the utility file, i copied the extracted folder to the first portal, and the operations dashboard is working fine.
But now i am not able to change the portal URL from the sign in, it is always connected to portal 1.
what should i do to use the same operations dashboard with both portals?
I am using portal for ArcGIS 10.5
thank u
DerekLaw
Esri Esteemed Contributor
Hi Ali,
Did you run the Operations Dashboard Utility in the second Portal installation as well? You need to add Operations Dashboard as a new portal item in both Portals.
Hope this helps,
AliBarakat
Thank u Derek, I will try this
will this allow me to sign in to the two portal from my machine?
DerekLaw
Hi Ali,
Not sure, but it's something to try to help you resolve your issue.
