operations dashboard summary widget
4557
12-06-2015 03:56 AM
MihaiFlorin-Cristian
I have a feature service published from an sde using ArcGIS for server 10.3, i used this service to add in a web map from an ArcGIS Online organization account, and then using that web map for an operation view using operations dashboard.
In this service with which i want to edit data, i don't have any entry.
In the operations dashboard when i create an operations view and add a summary widget, i select the field from which i want to have informations and select the operation for Sum, withouth having any data the widget returns a value, which reprezents the field number...
Has anyone encounter this type of problem?
Are there any solution?
Did I do something wrong when i published my data?
Thank you
RachelWeeden
Hi Mihai, if you are still having this problem could you please post a screenshot showing the configuration of the Summary Widget and the result that you see?
Thanks!
Rachel
Micah-JohnBeierle
Redacted Screen capture of Operations Dashboard Summary Widget Setup
