Operations Dashboard list widget is not displaying any values
3999
09-13-2018 10:10 PM
AmberKelly1
I am wanting to create a table/list/textural display on Operations Dashboard within ArcGIS Online. I am assuming that i can use the list widget informed by a table (hosted) layer. However when i add the table layer to the widget the display remains blank. If i hit the preview button it will display the table contents but once I commit to the changes and hit done the widget remains blank and never displays content on the dashboard itself.
Is this a misunderstanding on my part? Any suggestions?
Cheers
Amber
AmberKelly1
Hi Ryan,
I have found a solution - or rather was shown how to do this correctly. In the config of the list, under the list tab, you need to build the expression used to populate the list by using the curly bracket button. Hitting the drop down button bring up a number of attribute column options. See image below
Ops Dashboard, list
Hope this helps!
RyanTucker1
I'm having this issue as well...
Operations Dashboard for ArcGIS - Redondo Beach
AmberKelly1
Hi Ryan,
Ops Dashboard, list
Hope this helps!
RyanTucker1
Thanks so much, Amber. That did the trick!
AutumnMason
This is amazing! What an easy solution to such a pesky problem! Thank you!!
