Operations Dashboard Installation problem
4195
02-13-2014 03:20 PM
ValarmathyDornan
Hi
I am trying to install Operations Dashboard but unable to connect to the Proxy Server. Could you point me in the right direction please?
Screen shot attached
[ATTACH=CONFIG]31426[/ATTACH]
TifPun
Do you run into the same problem if you connect to arcgis.com from a web browser?
Recently the Dashboard team has released an updated version of the application (build 10.2.0.411) which addresses an proxy related issue. If yours is an older version (You can check the application's build number from your machine's Control Panel, as shown below), it will be good if you can get the latest build from ArcGIS Online and re-try.
A related blog post can be found here.
[ATTACH=CONFIG]31450[/ATTACH]
Thanks and please let us know if that helps,
Tif
