Operation Dashboard Widget Publishing
1510
08-29-2018 12:36 PM
AliAjami-Bakhtyarvand
I add one simple widget on the Operation Dashboard and when I work with debug mode of the operation dashboard my widget is fine and works well, but when I go to browser and try to check it I get error and it could not show up.
Could you please help me publish my widget and use them on the client side ?
Thank you,
Ali
Widget on the Debug mode on the operation dashboard.
Address for this file is on the "C:\Program Files\ArcGIS\Portal\apps\dashboard\extension\Weather"
My Error :
I find solution, I should publish the widget on the portal too.
DerekLaw
Esri Esteemed Contributor
Hi Ali,
I'm glad you were able to resolve your issue.
Just to be clear for other readers who may see this thread, your question and solution is applicable to the legacy, Windows-desktop based Operations Dashboard for ArcGIS app.
This does NOT apply to the current web-browser based Operations Dashboard for ArcGIS app. It does not support any custom development.
