Modify Symbology for Arcade Data Expression
1984
06-21-2022 11:07 AM
ankoure_Cambridge
I am working on an ArcGIS Dashboard and have a list element that is pulling its data from an Arcade Data Expression.
Ideally I would like to modify the "Line item Icon", which by default is just an orange polygon to be a circle that's color is dependent upon a column's values. I have already figured out how to generate the appropriate hex codes, I am just unsure how or if you can modify the default symbol, which I have attached below:
According to this document, the list item is unable to take advantage of the Icon properties or else I would just use that.
Has anyone dealt with this before?
Best,
Andrew
ZenMasterZeke
I have this same issue, and would appreciate any help as well.
YRP_GIS
Were you able to figure out this issue? I'm currently having the same issue.
sophered
im having the same issue!
PierreloupDucroix
MVP Regular Contributor
Up !
CEO of MAGIS
