Map with Operations Dashboard
888
08-08-2020 08:37 AM
LeeAnneDenney
Hello Community -
I have built an operations dashboard using a web map that references approximately 145k records aggregated by ZIP Code. Using the year/qtr field in my data, I added a selector by year/quarter with my data starting in q12016 and going through q32019. My aggregate values for the zip point data change appropriately when I select any year/qtr selection for 2016 or 2017 data. When I select 2018 or 2019 year/qtr data it doesn't return any data to the map. I also added an indicator on my dashboard referencing the same data and it returns the proper values when I select any year/qtr.
Just to check my data, I put a filter by year/quarter on my web map only (no dashboard) and have values returned when I select data any year/quarter.
Any thoughts on what I am missing to get the year/qtr selector to work for any time period on my map?
Thank you for your assistance.
by Anonymous User
Not applicable
Hi LeeAnne Denney‌,
Have you set appropriate Layer Actions under the Map settiings for when selection changes?
Cheers,
Cam
