Keep Selection Tool drawing on map when completed
503
02-14-2023 11:19 AM
BigLouC
Hi there,
I am using the Selection Tool in map portion of the dashboard as the user needs to create custom map searches for specific areas/boundaries that are outside of regular polygon layers.
The selection tool works fine and interacts with other elements on the dashboard.
The problem is that the drawing, of say, a lasso custom selection of four intersections, disappears when its completed. You may say, but your data is selected. Yes, when using point layer, my points are selected within the drawn boundary. But unfortunately, it doesnt remove all the other points and leaves the selected. Unless I am doing something wrong, I dont see the option to filter the Layer Action selected layer.
At least with the option to keep the drawn boundary, the flaw of not removing the other points on the map would be less noticeable.
Again, unless I am missing something and someone can assist, I would appreciate it.
Lou
