June 2026 Update - Layer x requires a selection from y
161
07-06-2026 08:45 AM
Steve_Graham
Is there a way to remove the new Info icon that shows up under a map in a dashboard?
When an action in the dashboard is used to show a feature in a map layer and 'Render only when filtered, box is checked - An Info icon ('Layer x requires a selection from y') appears below the map when there is no selection. The icon disappears and expands the map to fill the space when a selection is made. The map then contracts and shows the icon when an item is deselected again.
There is a similar x icon for when there is a layer reference error in the map.
This information can be conveyed elsewhere on the dashboard without resizing the map.
