June 2026 Update Causing Map Extent Conflicts with Embedded Dashboard URL Parameters
638
06-27-2026 01:18 PM
kevinskow
The June 2026 update in the last few days appears to have created an issue where the aerial extent saved automatically with a web map is conflicting with the aerial extent defined in the URL parameters for Dashboards embedded in a web page. An example Dashboard can be found at https://noaa.maps.arcgis.com/apps/dashboards/f5eaf19924af427aac8d173d6328758e#extent=-92.83,43.00,-9.... Refreshing the dashboard several times (or trying in different browsers/private windows) results in the default map extent varying between the one saved with the web map and the dynamic URL parameter, seemingly at random. This dashboard worked great up until this update. Does anyone have any tips for getting around this issue?
MartinCopping
Thanks for bringing this to our attention! I strongly recommend that you contact Esri Technical Support and open a case.
You can do that through your My Esri or the Esri Support App
Martin Copping
Product Manager, ArcGIS Online - Dashboards
Scott_Sambell
We also have this issue on at least 20 dashboards., completely crippling existing systems.  I'll submit a ticket for it.  If anyone already has done and has a bug number can they paste it here?  Thanks.
Scott
WillyG
I've just discovered that on most of our dashboards if I remove the pan parameter and leave zoom enabled it will zoom as intended. Almost like there is a conflict between the two.
