June 2026 Update Breaks List Display
710
6
06-26-2026 12:07 PM
ArielLow2146
With the June update my list element is no longer showing the full height of the content.
Here is the link to the dashboard: https://orleg.maps.arcgis.com/apps/dashboards/6e550cda0fcd49b28655afcd54068424#
LakesGISMaps
Same  here.  The update totally changes my list display settings.  The width, outlines, spacing.  Good 'ole AGOL updates for the win:
SandraLuken1
There was a fix installed on Friday night for something similar, can you please re-test and advise if you are no longer seeing this issue.
StephanieW
Hi @ArielLow2146 If you open the list configuration and then hit "Done", does the rendering issue resolve? I believe this may be related to a known behavior and this workflow should refresh the template setting.
ArielLow2146
@StephanieW opening the list configuration then clicking done doesn't resolve the issue. I was also able to create a new dashboard from scratch using the same data expression and html for the list and reproduce the behavior.
MartinCopping
Thanks for bringing this to our attention! The patch referenced that was going out on Friday did not seem to resolve the issue you are having, so I recommend that you don't hesitate to contact Esri Technical Support and open a case.
You can do that through your My Esri or the Esri Support App
Martin Copping
Product Manager, ArcGIS Online - Dashboards
ArielLow2146
@SandraLuken1 and @MartinCopping confirming that I'm still seeing the behavior. I created case #04207631 last week.
