Indicator Expressions
1436
08-25-2022 07:03 PM
JonathanMcD
Apologies for the question, despite using AGOL for years I've never had the chance to sit down and learn Arcade.
I've an indicator that shows a value that can range between 0 and 5 based upon a single value held in the dataset. I'm wishing to include a small text description in the bottomText based upon the value returned.
Is this possible in an indicator?
Basically;
if a value is >0 but <1 , returns "a",
if a value is >=1 but <2 , returns "b" etc
In the indicator, if I add bottomText: Sdatapoint ["value"] >0 <1,
a value of True is returned, which is fine....but my lack of knowledge prohibits me from taking this further.
Thanks in advance.
KenBuja
Yes, you can do this. First in the indicator tab, click the Enable button in the Advanced Formatting section.
Next, make these changes to the Expression. You'll be adding the code and uncommenting the bottomText properties.
var value = $datapoint["value"];
var bText = When(value == 0, "z",
      value < 1, "a",
      value < 2, "b",
      value < 3, "c",
      value < 4, "d",
      value <= 5, "e",
      "n/a")
return {
    //textColor:'',
    //backgroundColor:'',
    //topText: '',
    //topTextColor: '',
    //topTextOutlineColor: '',
    //topTextMaxSize: 'medium',
    middleText: $datapoint["count_OBJECTID"],
    middleTextColor: '',
    middleTextOutlineColor: '',
    middleTextMaxSize: 'large',
    bottomText: bText,
    bottomTextColor: '',
    bottomTextOutlineColor: '',
    bottomTextMaxSize: 'medium',
    //iconName:'',
    //iconAlign:'left',
    //iconColor:'',
    //iconOutlineColor:'',
    //noValue:false,
    //attributes: {
      // attribute1: '',
      // attribute2: ''
KenBuja
      value < 1, "a",
      value < 2, "b",
      value < 3, "c",
      value < 4, "d",
      value <= 5, "e",
      "n/a")
return {
    //textColor:'',
    //topText: '',
    //topTextColor: '',
    bottomText: bText,
    //iconName:'',
    //iconAlign:'left',
    //iconColor:'',
    //noValue:false,
    //attributes: {
      // attribute1: '',
      // attribute2: ''
JonathanMcD
@KenBuja
This is absolutely perfect, thank you. This is really helpful.
One final question;
Using Arcade doesn't allow me to then dictate the values and decimal places. Is it possible to set places to 2 using, somewhere, the round function?
JonathanMcD
Just replying to myself that just a little help is sometimes enough to push someone in the right direction.
I answered my own question with;
middleText: round ($datapoint["avg_Score__Overall_mean"],2)
