Icons issues on indicators - June 2026 update
493
06-30-2026 05:29 AM
AlaC
This dashboard was built on Saturday June 27th, after the June 2026 update.
The new indicator sizing customisations are fantastic (pic 1).
Today, however, when I went to use the dashboard, the icons are suddenly tiny in size (pic 2).
I don't want middle text, only the icon.
How can I get my dashboard back to looking/functioning like pic 1?
It uses very simple advanced formatting, as shown below:.
Cheers
return {
  //textColor:'',
  //backgroundColor:'',
  topText: 'Dolphins',
  topTextColor: '',
  topTextOutlineColor: '',
  topTextWeight: 'bold',
  topTextMaxHeight: 20,
  //middleText: '',
  middleTextColor: '',
  middleTextOutlineColor: '',
  middleTextWeight: 'bold',
  middleTextMaxHeight: 45,
  bottomText: $datapoint.SUM_NUMBER_OBSERVED,
  //bottomTextColor: '',
  //bottomTextOutlineColor: '',
  bottomTextWeight: 'bold',
  bottomTextMaxHeight: 30,
  iconName:'icon1',
  iconAlign:'left',
  iconColor:'',
  iconOutlineColor:''
  //noValue:false,
  //attributes: {
    // attribute1: '',
    // attribute2: ''
MappyIan
If you change the middleTextMaxHeight value to something bigger does that make the icon appear bigger?  It seems to accept values from 1-100. I'd set this to 100 and see if it does anything.  Beyond that, I've no idea I'm afraid.
StephanieW
Hi @AlaC This is a really cool Dashboard! I tried to reproduce this in my own but am not seeing the same behavior even using the same set up and your SVG image. I think this is specific to your Dashboard and think the best next step would be a Support case so we can take a closer look at the configuration and other potential contributing factors. https://support.esri.com/en-us/contact
SandraLuken1
An update was made several hours ago so the icon size should be improved now. Do reach out to support as Stephanie recommended if you are still encountering the problem.
