HTML Table in Indicator
1277
03-14-2024 12:54 PM
michael_vetter
I have an HTML table within an indicator to show the percentage of overdue 311 cases. Recently, I noticed that I needed to reformat the table because the wording causes the table to expand vertically which makes the user have to scroll to read the information. When I reformat the tables, the tables no longer extend all the way to the edges of the indicator like before. I didn't change anything with the width of the table only the cell that should contain the text.
Before:
After:
jcarlson
Can you share the formatting you have on the HTML? Hard to diagnose what's going on without that.
- Josh Carlson
Kendall County GIS
michael_vetter
Thanks for the reply. Below is my code for the table. The display expression is a simple if percent overdue is greater than 0 then display the text. Attribute1 is percent overdue and attribute2 is percent not overdue.
<figure class="table" style="width:100%;">
    <table>
        <tbody>
            <tr>
                <td style="background-color:#ff9999;color:#030202;display:{expression/noDisplay};width:{expression/attribute1}%;">
                    {expression/attribute1}% Overdue
                </td>
                <td style="display:{expression/noDisplay};width:{expression/attribute2};">
                    &nbsp;
                </td>
                <td style="display:{expression/display};width:{expression/attribute2};">
                </td>
            </tr>
        </tbody>
    </table>
</figure>
