How to make data expression that finds intersecting features faster?
5181
11
01-25-2023 04:40 AM
NygrenOhto
How can I make the following data expression faster? I have a feature layer with 5500 rows and another one with 3175 and it takes this script 5:30 minutes to run through. That's way too long.
I am trying to create an indicator that compares data from two different years in certain areas in a city by checking intersecting population data squares with regions of a city.
var portal = Portal("https://arcgisportal.xxxx.fi/arcgis/");
var areas = FeatureSetByPortalItem(portal, 'xxxx719ebb25xxxx968694axxxxxxxx', 3, ['*'], true);
var sql = "area_name = 'xxxxxxx'";
var filtAreas = Filter(areas, sql);
var stat2021 = FeatureSetByPortalItem(portal, 'xxx8abda0xxxx483xxxxxxxx', 0, ['he_vakiy'], true);
var sql2 = "he_vakiy > 0"
var stat = Filter(stat2021, sql2)
//var stat = Intersection(stat, filtAreas)
var features = [];
var feat;
for (var poly in stat) {
//Console(poly)
var pts = Count(Intersects(poly, filtAreas));
Console(pts)
feat = {
'attributes': {
'he_vakiy': poly['he_vakiy']
// Push feature into array
If(pts > 0){
Push(features, feat);
// Create dict for output FeatureSet
var out_dict = {
'fields': [
{'name': 'he_vakiy', 'alias': 'population', 'type': 'esriFieldTypeInteger'}
'geometryType': '',
'features': features
// Convert dictionary to feature set.
return FeatureSet(Text(out_dict));
NygrenOhto
I tried this change as well, but it didn't make any significant changes to the speed. I didn't time it but based on how long it felt.
Thanks for the help!
-Ohto
NygrenOhto
I managed to make it A LOT faster by using Disjoint() instead of Intersect().
Sample:
var portal = Portal("https://arcgisportal.xxxxxx.xxx/arcgis/");
var areas = FeatureSetByPortalItem(portal, 'xxxxxxebb254f1xxxx9xxxx1cdfxxx', 3, ['*'], true);
var sql = "area_name = 'xxxxxx'";
var stat2021 = FeatureSetByPortalItem(portal, 'xxxxbda0144xxxx3e8476d6xxxx', 0, ['he_vakiy'], true);
var features = [];
var feat;
    for (var filtArea in filtAreas)
        //Console(poly)
        If(Disjoint(poly, filtArea)) {
            continue;
        feat = {
            'attributes': {
var out_dict = {
    'fields': [
  'geometryType': '',
-Ohto
